I am having issues when I run the *.scr file in AutoCAD LT. The *.scr file contains coordinates of small rectangles that fill up a big rectangle. However, rectangles are not getting generated at proper coordinate points. The issue does not occur if I directly paste all the command text from the *.scr file into AutoCAD command line. Also, the script file works if the work plane is zoomed to about 10 m^2 square size.
I am attaching the *.txt file with this post. Please convert the text file to *.scr format.
Please let me know if this a syntax issue, or an internal AutoCAD issue.
Thank you.
