Script file does not render properly
akohliSUL2Q
akohliSUL2Q
I am having issues when I run the *.scr file in AutoCAD LT. The *.scr file contains coordinates of small rectangles that fill up a big rectangle. However, rectangles are not getting generated at proper coordinate points. The issue does not occur if I directly paste all the command text from the *.scr  file into AutoCAD command line. Also, the script file works if the work plane is zoomed to about 10 m^2 square size.
I am attaching the *.txt file with this post. Please convert the text file to *.scr format.
Please let me know if this a syntax issue, or an internal AutoCAD issue.
Thank you.
h_s_walker
It seemed to work fine on LT2016. I've attached the resulting drawing as well
Howard Walker
Left Handed and Proud
cadffm
Forgot to manage your object snaps?
Acad default setting is to ignore osnaps for keyboard input, but consider it in automation!
Add osnap non to each coordinate input,
or the much better way: set acad to ignore osnaps for coordinates, also for automation.
Sebastian
WeTanks
It seemed to work fine on 2023.
Please take a look at this recording.
Could you confirm the following?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
akohliSUL2Q
It works. Thank you so much.
