I'm a structural engineer and I draw a lot of structural details. My detail sheet is set up for 1"=1'-0" details. When I insert one drawn at 1"=1'-0" I use a scale factor of 1. When I have a detail drawn at 3/4"=1'-0", I insert it with a scale factor of .75, etc. This has worked "fine" for years, but lately I've noticed that when the detail is drawn at 3/4"=1'-0" or 1/2"=1'-0", the vertical dimensions are darker than the horizontal dimensions. This only happens on details that are not 1"=1'-0". I use a True Type font for the dimstyle.
Any ideas on how I can fix this?
Thank you
Creating a viewport for each detail will take too much time. Maybe my problem is using a TrueType font.
You should listen to the advice you have been given and adjust your workflow since your current one is causing problems..
Why are you responding to my signature quote instead of adjusting your workflow?
Sorry. I thought it was a comment.
Adjusting my workflow doesn't work. I sometimes have 20 details on a sheet. The time it would take to setup individual viewports would be rediculous. I believe we have different situations.
