AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Scale size
4 REPLIES 4
dycoengineering
314 Views, 4 Replies
Scale size
I'm working with autocad LT 2021.  Is there a way to see what scale a drawing is in?
4 REPLIES 4
pendean
in reply to: dycoengineering
You should be drawing at 1:1 scale all the time: are you not?
Otherwise you need to know the true dimension of something in the drawings, then measure it, and work out what scale it is.
HTH
dycoengineering
in reply to: pendean
I was just curious, we get dxf's in from customer and sometimes they are not to scale.  Didn't if there was a way to see what scale size they used.
pendean
Thanks for the update: only way to do that is to have a known dimension of measurement in the DXF file (and what unit it is using, mm or inch or cm or foot or meter or ...).
dycoengineering
Ok, that what i been doing, just hoping for an easier way.
Forma Design Contest
Technology Administrators
