Quite a simple beginners question - I think!? I am moving over to AutoCAD LT from Drawing Express. Drawing express has a 'roof tiles' command in which you select the tile ie. slate, clay, interlocking etc and then you select the vector you want and it covers that line with the roof tiles and roofing batten in section.
Is there an equivalent in AutoCAD LT? If not, what is the most efficient way of doing it?
Solved by pendean. Go to Solution.
Hi! AutoCAD LT is for general use, but the Architectural Desktop and MEP versions have this app under the Deail button. otherwise you need to copy and paste detail of tile in section.
