I recently had a fatal error in AutoCAD LT 2015. When re-starting the programme, my right click personalisation preferences were reset. I have set them back to how I want them, but the edit mode is not behaving.
I have it set to the following:
Default Mode - Repeat Last Command
Edit Mode - Shortcut Menu
Command Mode - ENTER
This is how I would like it to be set.
However, when I right click in the drawing (when something is selected, but not in a command) it repeats last command rather than bring up the shortcut menu as it is set.
Anyone else had this problem? And if so, how was it fixed?
Solved by user181. Go to Solution.
