right click customisation
aehammons
aehammons
I Right click on the command line go to options and then to user preferences and then click on right click customization and check all three boxes for enter last command and apply and close and the short cut menu unchecked it's box and I do it again and it does not work
pendean
Community Legend
Community Legend
The variable that controls that checkbox is called SHORTCUTMENU: if you type it at the commandline then hit <enter> what setting does it show?
Paul_Gander
If you only want right-click to always mean 'ENTER' or 'Repeat last command' then leave the 'Shortcut menus in drawing area' box unchecked on the 'User Preferences' tab.
Otherwise at least one 'Right-click Customization...' option must be set to 'Shortcut Menu'.
jayhar
In the Right-Click Customization dialog box, select Turn on Time-Sensitive Right-Click,
change preferences to to Right-click with time delay with Repeat last command and increased the time-delay to 450 milliseconds (was 250) because it would not always work.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
