Remedy for splined polylines not showing dashes?
erikflatmo
Message 1 of 13
erikflatmo
How can I get splined polylines to display dashes consistently? When I adjust the LTSCALE, the dashes appear only inconsistently - some parts dashed, some parts not. I've also tried PLINEGEN. Does anyone know a work around for this? I just want even dashes along a splined polyline. Thanks.
Replies (12)
Message 2 of 13
paullimapa
Message 3 of 13
pendean
Community Legend
Community Legend
@erikflatmo ... or change the linetype scale of the spline, it may help.
With SPLINEs you have to understand the spacing between the "points" of that spline and the space your fixed-spacing dashed line needs to display; it requires a lot of manipulation.
Consider trying the linetype DASHED2 vs just using DASHED as well (the former is coded to be shorter).
Message 4 of 13
lauri_barnhart
Hello, @erikflatmo,
Just checking in—did the responses shared by @paullimapa or @pendean help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
Message 5 of 13
erikflatmo
I am drawing electrical circuits. At this point I have to go in and
manually draw the dashes as little arcs for each “dashed” spline.
Message 6 of 13
h_s_walker
@erikflatmo Can you show us an image of what you're wanting to achieve. The spline not selected in the image below has a linetype scale of 0.2 and as you can see both it and the selected spline show dashes quite well
Howard Walker
Left Handed and Proud
Message 7 of 13
erikflatmo
Here are ARCS that look great. But you can see the two SPLINES do not show even or consistent dashes. This is the LTSCALE adjusted.
Message 8 of 13
erikflatmo
LTSCALE does not work for me in this case - either the dashes are too small or irregular. See my example below. Thanks
Message 9 of 13
erikflatmo
No not yet
Message 10 of 13
erikflatmo
I get it that it's difficult but still would like a solution. Please see my example below.
Message 11 of 13
erikflatmo
I need it to be a spline, not a pline. I am drawing electrical circuits and they should be curved not segemented.
Message 12 of 13
pendean
Community Legend
Community Legend
There is none is the spacing between your SPLINE "points" are too short for your chosen linetype. Try a different or shorter linetype, for example DASHED2 is shorter spacing than DASHED, or space out your spline point further.
You're fighting a SPLINE limitation that's not truly fixable.
Share your actual DWG file for someone to help you out with your own content.
Message 13 of 13
obulesub
Hello, @erikflatmo ,
Just checking in—did the responses shared by @pendean  help clarify your question?
All the best,
Obulesu | Community Manager
