AUTOCAD LT 2025 crashes, slow operating
joshua_heardNSA6R
Observer Observer
joshua_heardNSA6R
Observer
Observer
I am running AutoCAD LT 2025 on a Dell Precision 3591 laptop with Ultra 7 core, 32GB RAM. Its a company laptop. I constantly have AutoCAD crashes (2-3 a day), AutoCAD lags (bad latency, sticky pointer, commands lag, etc....). I have had our IT try to fix issues, but to no avail. I don't think our IT knows AutoCAD well enough to help.  As far as I can tell the laptop itself is set up to run a program like AutoCAD without issue. What can I do or look for to remedy these problems?
@joshua_heardNSA6R - topic title has been adjusted for better findability. Original '[AutoCAD crashes, slow operating]'
paullimapa
FYI: LT forum is over here:
AutoCAD LT Forum - Autodesk Community
Make sure LT 2025 latest updates are installed.
Perhaps graphics card incompatible?
Try this:
At command prompt enter:
GFXDX12
0
Thats a zero, close & restart AutoCAD LT
If still no good, at command prompt enter:
GRAPHICSCONFIG
Select another option under 2D Display Settings
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@joshua_heardNSA6R Read this recent post from a valid resource about Dell Laptops with AutoCAD
https://www.linkedin.com/posts/shaanhurley_autocad-civil3d-cadmanagement-share-7427814542124187649-3...
Also ensure your LT2025 is updated to this level
rosie_lucas1
Hello @joshua_heardNSA6R,
Just checking in—did the responses shared by @paullimapa , @pendean and @Dhananjai_Gopika help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie| Community Manager
Rosie | Community Manager
