AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Reducing DXF file size
4 REPLIES 4
831 Views, 4 Replies
I have windows xp machine and autocad 2014 lis installed but when user give dxfout and dxfin command file size is not decreasing please give solution
4 REPLIES 4
Kindly attach your file here so we can examine it.
Thanks 🙂
pendean
DXF files are huge compared to dwg files, you cannot make them smaller and still be good DXF files. That is how DXF files are by their nature.
But you can ZIP them up to email if that's the only problem you are trying to solve.
Hii
I am mailing u the files which are not decerasing pls check and revert back
Irshad
pendean
Your file is littered with dgn linetypes, you need to clean up your files with modern versions of autocad's PURGE command
Items Purged | Purge Status
DGN ComplexData........... | Purged : 16108
Here is your file back, a lot smaller.
You probably need to clean up ALL of your dwg files, including the missing xref from the file you posted.
Technology Administrators
