I have windows xp machine and autocad 2014 lis installed but when user give dxfout and dxfin command file size is not decreasing please give solution
Hii
I am mailing u the files which are not decerasing pls check and revert back
Irshad
Your file is littered with dgn linetypes, you need to clean up your files with modern versions of autocad's PURGE command
Items Purged | Purge Status
DGN ComplexData........... | Purged : 16108
Here is your file back, a lot smaller.
You probably need to clean up ALL of your dwg files, including the missing xref from the file you posted.
