"co-ordinates" panel option is missing from my "View" ribbon.
b.downeyU9TEQ
b.downeyU9TEQ
I have detached my "co-ordinates" panel from the view ribbon on ACAD LT 2021 and shut down.
When reloading LT I've now found that the co-ordinates panel is now missing and there doesn't appear to be a way of reloading the panel into my ribbon?
The right click function on the ribbon no longer displays "co-ordinates" as a Panel option!
***POST TITLE EDITED FOR CLARITY***
h_s_walker
This is from LT2016 so should work.
Click the hamburger ringed in the image below
Howard Walker
Left Handed and Proud
b.downeyU9TEQ
Thank you for the reply but this is not the problem.
The issue I have is that the "co-ordinates" panel option is missing from my "View" ribbon.  The co-ordinates panel gives you quick access to the various UCS tools used for setting up and switching between UCS.
Unfortunately when rick clicking on the view ribbon my "co-ordinates" panel tick box is missing.
cadffm
Check you cuix
Command: ABI
ACADLT
Ribbon - TABS - [View 2D] -> is one of the item "View - Coordinates" ?
if not
Ribbon - PANELS - able to find a panel [View - Coordinates] ?
if yes
Drag this Panel to
Sebastian
b.downeyU9TEQ
Thank you for your reply.
See below in green text:
Command: ABI Command was CUI
ACADLT
Ribbon - TABS - [View 2D]-> is one of the item "View - Coordinates" ?
Yes "view - coordinates" was in the location under [View 2D]
However panel/option to "tick" panel was still not available.
Any other suggestions?
pendean
Community Legend
Community Legend
You detached it and moved it off screen most likely. Dual-screen setup? Reduce the program window size and look for it.
Or CUI command, select your workspace, turn on CUSTOMIZE on the right-side, expand the RIBBONS TAB section, find your missing panel, select it, and at the bottom ensure it is set to SHOW and DOCKED. Then APPLY and OK out of the CUI command after you click DONE button to stop workspace editing.
You can also select another workspace then go back to your workspace and see if that helps, or just RESET LT2021 to get everything back. Or a repair/reinstall of the program.
HTH
b.downeyU9TEQ
Brilliant
This worked!!!!
