QUICK PROPERTIES NOT SHOWING AFTER SWITCH TO AUTOCAD LT 2024
brownd1961
Observer Observer
brownd1961
Observer
Observer
I recently upgraded to AutoCAD LT 2024 and the Quick Properties dialogue box does not show.
paullimapa
Make sure QPMOD is set to 1
if that still doesn’t work reset it in the cui
https://resources.imaginit.com/autocad/customize-quick-properties-in-autocad#:~:text=If%20you%20make....
Paul Li
IT Specialist
@The Office
WeTanks
I've been there.
私も経験したことはある。
Please take a look at this recording.
この録画をご覧ください。
I fixed it by doing this.
こうしたら直りました。
(view in My Videos)
English is my second language.
Please don't worry if I make any English mistakes.
英語は母国語ではない
英語のミスをしても気にしないでください。
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
handjonathan
Hi @brownd1961
Thanks a lot for posting your question to the forums!   Has the solution suggested by @WeTanks & @paullimapa helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
brownd1961
Observer
Observer
QPMODE set to 1 didn't change the quick properties dialogue box.
When I changed drafting settings I had to toggle between static and cursor locations for it to wrok.
pendean
Community Legend
Community Legend
@brownd1961 wrote:
...When I changed drafting settings I had to toggle between static and cursor locations for it to wrok.
