AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Publish plot partial of the dwg only
6 REPLIES 6
SianSiam
190 Views, 6 Replies
Hello Everyone,
Recently, when using publish, it only plotted partial of the dwg like the pic below. I have been using the page setup settings for awhile. I have never had this issue with the said settings.
Thanks in advanced.
6 REPLIES 6
hwalker
in reply to: SianSiam
Can you post the drawing? Also a screenshot of your settings.
Howard Walker
Left Handed and Proud
pendean
@SianSiam Your image simply indicates your pagesetup parameters and your content as mismatched. Nothing more despite you assurance otherwise. Sorry.
If you'd like more assistance with deciphering the issue at hand, you'll need to share dwg file(s) here for someone to use your files to discover what might be triggering the result you wish to avoid.
Share when you can.
paullimapa
What if you use the Plot command on this drawing and then select the same page setup?  Does the plot preview look correct or also only shows partial?
Paul Li
IT Specialist
@The Office
SianSiam
in reply to: hwalker
@hwalker thanks for the reply. I managed to solve the issues.
SianSiam
in reply to: pendean
@pendean thanks for the quick reply. I have solved the issues.
SianSiam
in reply to: paullimapa
@paullimapa Thanks for the quick reply. I did that but I got the same result. The plot preview looked correct too when I was having the issue. I managed to solve the issues now.
Forma Design Contest
Technology Administrators
