At my office we are currently running AutoCAD LT 2000,2007, & 2008. My boss, who is running 2000, experiences a problem creating blocks and copying to the clipboard when working on a file that was created with a newer version of AutoCAD LT. He's come to notice that on every drawing that he can not use the copy to clipboard command or the block command, the "Proxy Information" box (attached is a print screen on the box) appears while the drawing is opening. I've been researching proxy objects and the only fix i can find pertains to AutoCAD 98-99.
If anyone knows of a fix or phrases to research please let me know. I'm researching the following: proxy objects, proxy information, associative objects, associative dimensions.
Again we're running AutoCAD LT 2000, 2007, 2008 and the error occurs with 2000.
Thank you.
