Hi I installed Autocad 2025 LT today and the properties & quick properties are blank! I always work with them both open, so this is very hard for me to deal with 😞
I have screenshots showing ted my line selected and the blank properties and quick properties. If anyone knows what has happened in this new version, please help!
There are some solutions offered at this link: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Properties-palette...
make sure you download and install 2025.1 LT update
Seems like there is something in your Windows registry that’s causing the problem. What if you create another user with local admin rights and sign in with that new user profile? Does that do anything differently with 2025 LT’s Properties window? Here’s another shot in the dark. Change Gfxdx12 to 0 and restart LT. See if that makes a difference. If not try GraphicsConfig and disable Hardware Acceleration. Any difference?
you can contact autodesk support here:
You are welcome…cheers!!!
