Properties boxes blank
cad_cow_24
cad_cow_24
Hi I installed Autocad 2025 LT today and the properties & quick properties are blank! I always work with them both open, so this is very hard for me to deal with 😞
I have screenshots showing ted my line selected and the blank properties and quick properties. If anyone knows what has happened in this new version, please help!
Replies (12)
user181
cad_cow_24
Hi, thank you for that. I will go through those solutions!
paullimapa
make sure you download and install 2025.1 LT update
Paul Li
IT Specialist
@The Office
cad_cow_24
it didn't work! 😞
paullimapa
If updating to latest doesn’t fix it have you tried the other solutions as pointed out in the link @user181 provided such as
reset AutoCAD LT
uninstall and reinstall
Paul Li
IT Specialist
@The Office
cad_cow_24
yep, tried each one! so annoying.
I'm uninstalling 2025 and going to go back to another version and hopefully it's still like i had it
cad_cow_24
Hi again Paul, I even tried resetting - uninstalling, re-installing. Nothing works.
It's been a nightmare evening; I then tried going back to 2022 and it proceeded to tell me that some registry key was missing and kept producing a fatal error.
Pure chaos especially when I am on a deadline for a project 😞
I have re-installed 2025 and am using it without properties which is excruciating for me.
Anyway, thanks for listening and trying to help! 🙂
paullimapa
Seems like there is something in your Windows registry that’s causing the problem. What if you create another user with local admin rights and sign in with that new user profile?   Does that do anything differently with 2025 LT’s Properties window? Here’s another shot in the dark. Change Gfxdx12 to 0 and restart LT. See if that makes a difference. If not try GraphicsConfig and disable Hardware Acceleration. Any difference?
Paul Li
IT Specialist
@The Office
cad_cow_24
Hi Paul
I haven't tried any of your ideas yet.....I will do so tomorrow and let you know!
Otherwise I guess I'll have to ring support?
paullimapa
you can contact autodesk support here:
https://www.autodesk.com/support/contact-support
Paul Li
IT Specialist
@The Office
cad_cow_24
thanks so much! 🙏
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
