Program that select blocks by name within a selected closed boundary
gschmidtAH4PP
Observer
gschmidtAH4PP
Observer
Observer
It's been 15 years since using LISP. I need a program that prompts to pick a closed boundary then counts specific blocks by block name. I have the counting done, I just need how to select boundary and use that boundary for block selection. Help please.
Greg
pendean
Community Legend
Community Legend
You only wish to count blocks inside a boundary of.... a closed pline or polygon? A window of your selection? a combination of shapes that defined a "closed" space?
And if the block is just slightly into the boundary? or only partially inside or outside it?
gschmidtAH4PP
Observer
Observer
Everything inside. It is polyline. Just a block for now but I can change/add for other things. Just having issues with the polyline selection and selecting objects inside.
pendean
Community Legend
Community Legend
@gschmidtAH4PP What year version of AutoCAD are you running? Latest ones (2023-24-25) have COUNT command, and one of the sub-options is to select a polygon to count inside it.
gschmidtAH4PP
Observer
Observer
I will be using LT. 2024.
pendean
Community Legend
Community Legend
That's a core feature (and the sub-option is OBJECT, not polygon)
