AutoCAD LT Forum
print error
2 REPLIES 2
1351 Views, 2 Replies
print error
I have just loaded the 2019 AutoCAD LT subscription onto my office workstation (upgrading from AutoCAD LT 2010)  and now I can no longer print to my plotter HP 1050C
Here is the error Message:
Thank you in advance - luckily I have not deleted my 2010 version so I can save down and print but I shouldn't have to...
Version:1.0 StartHTML:000000233 EndHTML:000002521 StartFragment:000001046 EndFragment:000002451 StartSelection:000001046 EndSelection:000002413 SourceURL:res://c:\program files\autodesk\autocad lt 2019\en-us\AcPltRes.dll/402
Job: - Plotted with Error(s) and Canceled Sheets
Job ID: 8
Sheet set name:
Date and time started: 1/8/2019 2:30:10 PM
Date and time completed: 1/8/2019 2:30:20 PM
UserID:
Profile ID: <<Unnamed Profile>>
Total sheets: 1
Sheets plotted: 0
Number of errors: 2
Number of warnings: 0
Sheet: 2018-16 A1 Plans-A0.0 - Canceled
File: M:\00 Projects Active\2018-16 Chartrand Renovation\2018-16 AutoCAD\2018-16 A1 Plans.dwg
Category name:
Page setup:
Device name: HP DesignJet 1050C by HP
Plot file path:
Paper size: Arch D - 24 x 36 in. (landscape)
MESSAGE: Error : The parameter is incorrect.
ERROR: The device has reported an unknown error.
ERROR: The publishing operation was canceled.
2 REPLIES 2
pendean
Your 1050c is too old for newer AutoCAD versions: start looking for a replacement, a popular replacement (you can find it second hand occasionally for even less money) is the HPT930 or explore the option of contracting out your large plot jobs if you are in a region where there is a lot of competition for that.
In the meantime you can print to PDF, then from your PDF viewer to the plotter.
in reply to: pendean
Thank you for confirming my suspicions. I'm not excited about this but we will find a way to deal with the inconvenience. Sorry for the duplicate post as well. i am new to forums and posting.
Maiju
Forma Design Contest
Technology Administrators
