AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Print Area on Paperspace
5 REPLIES 5
2129 Views, 5 Replies
I have tried to read other forums to get answers to this, but I have came up unsuccessful. My dotted print area in paperspace is not printed my sheets as centered, so I have to manually move my printable area "off-center" so that it prints in the center of the page. Any idea why it just wouldn't be centered in the printable area? To actually print that way?
Labels (1)
5 REPLIES 5
RobDraw
This is very doable but it dependent on your print settings and possible paper space content. Share a drawing with the title block.
Rob
cadffm
1. Pagesetup/PLOT dialog: Are you using CENTERED instead of a x/y Offset value?
2. What kind of Plot-Area: EXTENTS or Windows (if you have nothing outside the frame, use 'Extents'
3. Perhaps you using a paperformat with unregular unprintable.border settings.
Left 3mm, on the right 13mm => The middle of the printable area is not the middle of the paper
Check your Paper size definition (Plot, Plotter properties... CLICKme -> You can choose another papersize or create your own definition, pls do not change a standard definition)
Sebastian
in reply to: RobDraw
Hopefully this helps.
in reply to: cadffm
I don't know how I missed having the page centered in the plot dialog box. Thank you!
Bob_Zurunkle
OP I usually start by drawing the outline of my paper in paper space, on the defpoints layer, with the bottom left corner at 0,0
Then I do my page setup by choosing my output by Window, and pick 'center'
The only other thing I do is go into my properties for that sheet size, to reduce my margins to zero
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Technology Administrators
