Plotting
Plotting
Plotting
I am unable to batch plot any document, but printing a single page seems to work. Keep in mind I have adobe acrobat and it is working and updated, yet I get an error message that reads as follows:
PDF Output - No PDF Viewer installed. You can download a PDF viewing application such as Adobe Acrobat from the internet and try again.
Thanks.
Emmsleys
HI @Anonymous,
What do you have PUBLISHCOLLATE set to?
Sarah Emmsley
Technical Support Specialist
Emmsleys
In addition to my previous question you can also look to this Error: 'Device Not Found' when publishing to PDF in AutoCAD
Can you provide the AutoCAD LT release you are working in and which WIN OS you are running?
Have you had this issue previously or is this a new problem?
Sarah Emmsley
pendean
Community Legend
Community Legend
>>>...PDF Output - No PDF Viewer installed...<<<
The error message simply means the driver you used in AutoCAD cannot find your PC system's designated PDF viewer to show you the file after creation. It likely already created the PDF and it's sitting somewhere since this is an after-creation error message.
