I have recently started using AC lt 2017 and cannot find the Plotter Manager or Add A Plotter Wizard.
When I click on the Plotter Manager icon in Output or access it via the Print menu it takes me to my A360 files.
I have tried multiple searches within my system for the .exe files and have found nothing.
Any ideas?
Solved by pendean. Go to Solution.
Start OPTIONS command, and go here, what is the path? It should be
C:\Users\YOURLOGINNAMEHERE\AppData\Roaming\Autodesk\AutoCAD ver number\R-number\enu\Plotters
