Just the other day I wasn't having any issues, but suddenly when I attempted Print to PDF the PDF Line thickness was to large. I know Its not my drawing due to opening previous drawings that printed correctly and them having the same issue. anyone have any ideas of how to fix this?
Solved by pendean. Go to Solution.
I need to plot with Line weights, the issue is that When I print off of my Autocad this issue occurs, yet when I print from another computer using identical settings it prints correctly. I use the same template with specified line weights for multiple drawings and they have all worked correctly until now. Is there any other way to affect line weights other than altering them in layers? I'm also printing with No plot style.
I havent updated either recently but i believe I have the most current version of autocad. I have autocadLT 2020 and Win 10
Yeah, I've printed using this exact sheet size, scale, plot area and plot options before with no issues. The only difference I can see is that that image showing the relative print in now very messed up. I think I either messed some plotter setting up not on that page setup window.
unfortunately not allowed to post the file, But I have sent the exact file to a co workers computer and he was able to print it with no issues. I even double checked all settings. The only difference was that relative plot image
I created a blank file with a couple lines to show the problem. I attached the CAD, PDF, and Settings i used.
How old a version of AurtoCAD/LT are you running? This is what PLOT command brings up in your FILE on my PC, see the differences
I forgot to mention we save our files in the 2013 version sorry! (and unfortunately I need to do that as well)
