plot stamp
plot stamp
MarcoEN8GQ
plot stamp
MarcoEN8GQ
I am using AutocaLT 2023, I have the following problem, I have created a plot stamp (simple, only date + name) when printing to pdf (ctrl + p) it appears; but when exporting (EXPORTPDF) it does not appear, before (when I used another version) it worked, any solution or indication?
Patchy
try plot using dwg to pdf
or ask the LT group.
paullimapa
LT forum is here: AutoCAD LT Forum - Autodesk Community
But should work according to help: AutoCAD LT 2023 Help | EXPORTPDF (Command) | Autodesk
Could be a bug.  Have you tried LT 2024?
Paul Li
IT Specialist
@The Office
Valentin_CAD
@MarcoEN8GQ ,
Consider using the PUBLISH command instead.
Note: Printer driver corruption can cause items not to plot. Update or reinstall the printer driver.
or Try the other PDF Preset.
Otherwise you may need to open a support ticket:
Or Resetting AutoCAD to Default:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
ChicagoLooper
Hi @MarcoEN8GQ
Plot Stamp? 1980's? 1990's?
Consider using a FIELD instead of plot stamp. It's easier to control font style, text height, text color, text layer, freeze/thaw, horizontal/vertical orientation and its placement in either modelspace or on a layout tab..
You can add the Field so it's included and part of your titleblock(s).
Or you can insert a Field before, inside or after plain mtext.
Fields are friendly when plotting to PDF.
Chicagolooper
