plot preview - plotting a pdf
I upgraded to AutoCAD LT 2016 from 2007 LT because it looked like the last copy I would be able to purchase a license for.
For the past year I keep using 2007, mostly because I have never been able to get 2016 to plot a pdf, my most used option.
I do not even get a preview of the plot. When I hit the preview button it just cycles to the plot manager again.
Any help will be very greatly appreciated.
Frank
Emmsleys
Hi @AnonymousHello
Welcome to the Autodesk Community!
I need a bit more information from you.
  • What type of operating system are you running?
  • Have you applied all service packs?
  • If you log in as a different windows user on your machine does this issue still happen?
  • Are AutoCAD 2007 and 2016 on the same system?
  • Does this happen with all files even a brand new file?
Sarah Emmsley
Technical Support Specialist
pendean
Community Legend
Community Legend
Nothing has changed when it comes to plotting between the two versions, except for being able to choose built-in PDF drivers.
So let's start at the beginning: post a screenshot of your full AutoCAD/LT2016 screen with the PLOT dialog box in full view and "ready to plot" to PDF and let's see what you have going on.
I seem to have found a solution. Digging deeper in the Pdf setup in 2016 may be working for me. I will update if the problem continues. Thank you
Emmsleys
Thanks for posting back with an update, If the issue occurs again feel free to share any screenshots or additional information.
Smiley Happy
Sarah Emmsley
