Error when saving. Run RECOVER
Hi, we have been working on this one file that constantly causes errors (and sometimes locks up the machine) when AutoSave runs. Twitter support says it is almost always a corrupt file. How can we safely transfer the data to a new, uncorrupted file? Will merging them retain the corruption?
matthew.d
Hi @Anonymous,
Welcome to the community!
Apologies again for the trouble with your file. I have escalated this to case 11914289 for you and requested a call for you, but would also like to try and help troubleshoot the file in the meantime. It sounds like this is only happening on this particular drawing. If you can open another drawing, the original drawing may be corrupt and require repair. Here is how to repair corrupt AutoCAD files.
Is this error only occurring when you try to save? Have you tried exporting the model, do you get the same result?
You do have the option to copy the following between drawing if that's the route you would like to take:
  • Any drawing object
  • Blocks
  • External references
  • Layers
  • Layouts
  • Dimension styles
  • Text styles
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
pendean
Community Legend
Community Legend
Use RECOVER command to open the problem file, let the program fix any issues, then save and close. This almost always cures problems.
But if not, proceed to this next step afterwards:
Open a "good" file, or a new empty file, then INSERT and EXPLODE the problem file so it becomes part of this one. now SAVEAS and give it a new name. This almost always cures problems.
WBLOCK out all the content in modelspace to create an all new file.
john.vellek
HI @Anonymous,
I am sorry you are having this problem. Can you attach the file so I can take a look at it? Do you use any Extended Entity Data which might be lost during some clean up processes?
Does the file have external references or image attachments? Any special fonts?
Please bundle it up and attach so I can get this taken care of for you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. I am happy to assist you if the issue continues. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
