Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
If you are only looking at the basic geometry, this is easy. Normally I would suggest you download a trial of Plant 3D as there is a folder that contains this simple geometry.
I happened to have a copy handy of this folder so it is zipped up and attached to this post. Once you have put this folder on your computer you can use DesignCenter to browse and insert the contents or you can also make a tool palette.
Hi @Anonymous,
I am checking back to see if my post with the symbols attached helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
