Hi Eli @elIANNA73F4R,
That sounds frustrating. While I am not familiar with this error, it looks like it is indicating the PDF may be damaged or an unsupported format or that another application is tying to Open it rather than import it.
The things I would check:
- Confirm which application is sending up the error. While it may be occurring on import, I don't see the AutoCAD symbol on it, and something is trying to open the file.
- See if your coworkers can import the same PDF files you are getting the error with.
- What is the source of your PDFs versus theirs? If created on a different system, application, or version, test importing their PDF files.
- Are you using the same version of AutoCAD as your coworkers? Check updates also, from the ABOUT command.
If you are still seeing the error after checking these, you might consider testing resetting the AutoCAD user profile (see How to reset AutoCAD to defaults).
Please let us know if that helps.
All the best,
	 Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider
 Liking the post.
