I recently ran into a problem where I cannot import pdfs into cad. I believe this issue is only on my computer since my other co-workers can insert pdfs in the same dwg that I'm trying to insert pdfs. please let me know if there's any way I can resolve this issue, it will be a huge help.
THANKS IN ADVANCE,
❤️ ELI
[This post has been edited for clarity by cheryl.buck]
Solved by pendean. Go to Solution.
Hi Eli @elIANNA73F4R,
That sounds frustrating. While I am not familiar with this error, it looks like it is indicating the PDF may be damaged or an unsupported format or that another application is tying to Open it rather than import it.
The things I would check:
If you are still seeing the error after checking these, you might consider testing resetting the AutoCAD user profile (see How to reset AutoCAD to defaults).
Please let us know if that helps.
All the best,
Both of our systems are the same, they have been importing the pdfs for me since I'm not able to.
1) 2022.1.1 is the latest variant: if your ABOUT command does not show this then you need to get that update installed. Restart your computer afterwards, then try it all again. If you already have it, then reset your LT2022 and see if that helps.
2) Too bad, not much anyone here can do for you then. If the above did not help, start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Good luck.
hello, I did a total of 3 updates to my Autodesk application and was praying that it will fix my pdf import. and it did!! I celebrated so hard because without the pdf import it was a pain in the rear doing my job. My productivity is back on track !! thanks to all for helping.
