AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Pasting Blocks Error - Attributes are shifted
2 REPLIES 2
cjshaw14
138 Views, 2 Replies
I recently created a block and it functions correctly when entering values for the different attributes. However when I copy and paste the block to one particular dwg the attributes are shifted to the left. I tried pasting to other dwgs and there is no problem. See attached for visual.
2 REPLIES 2
pendean
in reply to: cjshaw14
More often than not, "text" will shift due to a font substitution, a STYLE setting difference from source and destination files, OR a named block with a different look and placement of attributes was already defined in the one destination file (but not the other destination files as you indicated).
By chance, which of those possible three scenarios does your commandline and alert pop-ups id AutoCAD suggest was the culprit? CTRL+F2 if you need to see more than the one or few lines you have as default may help.
cjshaw14
in reply to: pendean
Thanks for the quick reply! I had actually changed the text height and placement on a few attributes. Solved by purging the dwg and works now.
Thanks again
Technology Administrators
