Paste Special (screenshot) issue
markWM97U
markWM97U
Community Visitor
Community Visitor
Issue with using Paste Special command to embed a screenshot. Instead of a picture outline box I'm getting a single line and this message "Failed to create object. Make sure the object is entered in the system registry".
The problem doesn't happen all the time so it's hard to say what exactly triggers this issue.
Has anyone ever encountered such problem? if so, how did you go about solving it?
brian.strandberg
There is a technical support document on this issue.  "Error: Failed to create object. Make sure that the object is entered in the system." inserting imag...
Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
freddcad425
"embed a screenshot"... is this a different process than simply pasting from your clipboard?
pendean
Community Legend
Community Legend
The latter, plus all the challenges that may add.
