We keep getting these e-mails, sometimes 10 to 15 times a day:
Date: Mon, May 9, 2016 at 11:34 AM
Subject: Autodesk Registration & Activations: Autodesk AutoCAD LT 2016 2016 (xxx-xxxxxxxx)
To:
Thank you for registering your Autodesk product. The information you provide helps us serve you better in the future and helps you stay informed about Autodesk products and services.
Serial Number: XXX-YYYYYYYY
Product: Autodesk AutoCAD LT 2016 2016
Computer Name:<NAMEOFCOMPUTER>
If you have requested an activation code through the Autodesk website, you may need to follow these additional instructions to complete your activation:
Activation Code:
WHY??!?!?!
Hi deitechsupport
I am sorry to see that you are having activation issues. Can we try a manual activation to see if fixes the problem for you?
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
I think the problem stems from the fact that the software was purchased and put under an incorrect e-mail address (mine) and it was corrected to our general software e-mail address for registration. It is working fine but I keep getting all these activations for the same serial number over and over again. So I doubt a manual activation will help. Chatting with a representative, they told me to uninstall and reinstall which is not a very good suggestion!
Hi @Anonymous,
I suggest that if the manual activation did not work as described in my prior post, that contacting the account activation/registration team would be in order.
Hi jalbert,
I suggest trying them one more time. We are making a whole-hearted effort to step up our game for our customers.
Hi jalbert,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Hi jalbert,
I have escalated your case so we can get this resolved for you. You should be hearing from our support team within the next few days.
It sounds like the Subscription Term doesn't exactly match the end date of the asset but they should be able to get this corrected for you.
Thanks for your patience.
