oSnap not working, have checked all settings and reset
MHINSONCDC
Message 1 of 14
MHINSONCDC
I am running autocad 2022 LT and use it many hours a day every day of the week and just had a new problem show its ugly head this morning in a drawings that I have been working on for multiple days.  oSnap is not grabbing corners, midpoints, or referencing off of certain rectangles.  If I hover over the corner and press "tab" multiple times, the box will eventually appear.  If I have to do that everytime I might as well quit and join a roadwork crew.
I have tried the following:
turned snaps on and off individually
unchecked and rechecked the magnet box
confirmed the colors are still the same
reset autocad settings.
Any help is MUCH appreciated!!!  Happening on both my desktop and laptop so it must be a drawing file issue?
thanks!
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
So... if you open a brand new blank DWG file, draw some lines, circles and rectangles, your same running OSNAPs completely fail in the same exact way too?
Or is the problem limited to this one file with only these objects in them?
Message 3 of 14
MHINSONCDC
So in a new drawing the problem is gone and it is something in that particular drawing.
When I copy and paste the original element that was giving me trouble into the new (just worked) drawing, it does not work and behaves the same as in the bad drawing.  Can it be saved?
Message 4 of 14
h_s_walker
Do an AUDIT on the "Bad" drawing and say YES to repairs
Howard Walker
Left Handed and Proud
Message 5 of 14
pendean
Community Legend
Community Legend
EXPLODE the content in the BAD drawing, and keep exploding until there is nothing to explode; not try it all.
Message 6 of 14
MHINSONCDC
This did not fit ix
Message 7 of 14
MHINSONCDC
I have exploded everything visible, cntl A to select all and exploded that.  I tried setting everything to the 0 layer and repeated the process.  It is still not working
Message 8 of 14
MHINSONCDC
(I also downloaded autocad LT 2023 this morning and the problem still persists.
Message 9 of 14
pendean
Community Legend
Community Legend
@MHINSONCDC  the problem is your file: nothing else.
Share it here for others to explore it or ask the file creator about fixing it and resending to you.
Message 10 of 14
MHINSONCDC
Thank you for helping look into it.  The file is attached, the red rectangles are the ones that I cannot grab the corners to.  I live in the stretch command so being able to grab the right corner is important to me.  Unfortunately I am the creator of the file, Is there something I did or is there anything I can do to prevent this from happening again?
Message 11 of 14
h_s_walker
Well the first problem is that those "4 red lines" are not 4 lines. See the image below. Even after using OVERKILL those "4 red lines" were still 10 red lines.
After using overkill however the endpoint snap worked just fine
Howard Walker
Message 12 of 14
cadffm
Are you talking about the waste of objects on layer 'LAYER 2 GRAY LINES' only?
Or do you have problem on all objects (objects where you try to use an object snap) ?
As Test: Run OVERKILL an delete all duplicates, then try it again, as first test with osmode=35)
(and as general hint, geometric center as running osnap is not a good choice, also nearest - is rarely a good one)
Sebastian
Message 13 of 14
MHINSONCDC
It is working now. So the clutter had thrown it off. Thank you!!!
Message 14 of 14
MHINSONCDC
Understood now, the overkill fixed it. Thank you!!
