I am trying to use excel 2016 as a "Table of Contents" to link out to open drawings in our server database. I used the hyperlink() function to create the link to the .dwg file but it will not open the dwg. It will only open a new instance of AutoCAD LT 2023 instead of the linked drawing. I currently am using a workaround with a hyperlink to the folder containing the drawing where the user then has to click the drawing to open it but I want to eliminate that step. If anyone can please help me with this, I would greatly appreciate it!! Thank you!
I get a warning for opening the file.
Generally only plot from model space but some of the drawings are using layouts. We are trying to organize our database of drawings from the last 20-ish years so there are some inconsistencies with how things have been done. However, no matter what type of dwg I try to open, only a new instance of AutoCAD LT opens, without opening up the DWG.
It will only open the default "new File" when I click the hyperlink.
AutoCAD L Tis the default program and will open the DWG files when I click them in file explorer.
This is an entirely new process being implemented.
The alert is just an annoyance. I don't mind it being there as long as it actually opens the DWG when I click Ok.
