I am admittedly very green on AutoCAD. I'm using LT 2019, and when I try to offset, I'm able to set the distance, I click on the line to offset, then move the mouse to the side I want the offset to go, and sometimes, even though it shows the new line appearing on that correct side, when I click to commit the action, the new line appears on the OTHER side of the original line. This doesn't happen every time, maybe 25%, but when it does, it will consistently put that offset line on the incorrect side. I have had this issue on a couple of computers, so I don't think it's a computer/mouse issue.
Solved by ChrisPreece. Go to Solution.
Solved by pendean. Go to Solution.
Hi @mhardyV7YS2,
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
