Objects with Z coordinates
allenrtravel
Observer Observer
allenrtravel
Observer
Observer
I work with AutoCAD 2014LT. I have discovered that some of my lines have Z coordinates. This impacts several commands- fillet, trim, hatching, etc. I haven't set up my work this way. How do I draw with x and y only, without z?
cadffm
Impossible. If you are using object snaps on an objects with z/=0, you catch X Y AND Z value from this point.
You can use pointfilters (.XY), i am thinking you don't want to do it every time.
The better way: Make sure you don't have objects with z/=0, so you can't catch coordinates from points z/=0.
See also oldet posts
Example: https://www.google.de/url?sa=t&source=web&rct=j&url=https://forums.autodesk.com/t5/autocad-lt-forum/...
Sebastian
jayhar
Can't draw or edit in X or Y plane when in a side view in AutoCAD Click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists, Please give me a bit more detail on this issue so we can continue to work towards getting this solved. ?
Thanks You
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
allenrtravel
Observer
Observer
What I am experiencing is objects (particularly lines) that have z coordinates. I discover this when some commands don’t work, such as trim, fillet, extend and hatch. If I select 2 or more objects and then view their properties I see that they have z coordinates. I have not set up my drawings this way as far as I know.
cadffm
Jayhar missunderstood in this case, but there was another answer too (and follow nested links too, please)
https://forums.autodesk.com/t5/autocad-lt-forum/objects-with-z-coordinates/m-p/8279399#M168847
I am pretty sure your source issue comes from objects WITH z-values and you are using objectsnaps, so you snap z-Values of these points too.
From copy&paste objects, or xrefs, whatever.
Or you had one time insert the wrong coordinate (incl. Z value like 0,0,44), thats possible too.
There is no variable, you always working in a 3D room, in LT too.
Sebastian
