AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
No menus in AutoCAD LT 2014 running on Windows 8 - how can I get this resolved?
57 REPLIES 57
Message 22 of 58
1426 Views, 57 Replies
The menus that were along the top of the LT window since I first installed the product years ago have now disappeared, rendering the product unusable. I need to get back to where I was on Monday or else my software is nothing more than an expensive space holder in my system.
I uninstalled LT and reinstalled it - no change.
So far - no response - is there another source of help at Autodesk? This is the first problem I have encountered that required support but it has stopped production and I really need to get an answer.
So - two questions - how do I get AutoCAD LT 2014 back to its original state, and if there is no answer for that, where else can I go to get some help on this issue. It is getting to be very frustrating and I need to get back to work.
57 REPLIES 57
Message 41 of 58
pendean
in reply to: matthew.d
This OP has 6+ posts on the same topic: it would be nice if we all stuck to this one moving forward https://forums.autodesk.com/t5/autocad-lt-general-discussion/no-menus-in-autocad-lt-2014-running-on-...
Message 42 of 58
in reply to: pendean
Okay, updated, again, rebooted the computer, and got a screen capture, also, I don't know what caused the menus to disappear in the first place - I was working, then the menus went away. Clearly I pressed the wrong button, but I could not find a way to back that out, nor restore the menus.
Message 43 of 58
pendean
At the commandline, type RIBBON then hit the <enter> key on your keyboard. What happens?
At the commandline, type WORKSPACE then it <enter> on your keyboard, then type ? then hit <enter> again: the commandline will show two or three names at the bottom, name them here.
Message 44 of 58
Emmsleys
Does resetting to defaults help? Has this happened in the past.
At the top-left of the application window, on the right end of the Quick Access toolbar, click the drop-down menu Show Menu Bar.
Post back if you are still having a problem with the menubar
Sarah Emmsley
Technical Support Specialist
Message 45 of 58
Emmsleys
@Anonymous,
Can you provide a screenshot of your user interface?
Sarah Emmsley
Message 46 of 58
I think there was a Windows update - one of those updates that occur when you turn off your system.
I have not updated the graphics card.
I cannot find an AutoCAD or Autodesk section in the Windows program list - if I right click the down arrow I get a list of programs and a search function. If I enter "AutoCAD" I get several options, but none of them lead to a "restore" function. There is an import/export but I need to enter a file name to import what it is I want to restore, and I don't know the file name or the path to that file.
Message 47 of 58
pendean
If you have Windows 8 Operating System:
1. Click the Windows button to access the Start Screen.
2. Right-click the bottom of the screen.
3. Click the down arrow to access all the installed apps.
4. In the AutoCAD/LT 2014 section (usually to the far right), click "Reset Settings to Default."
Or if you have Windows 8.1 Operating System:
2. Move your cursor down and click the down arrow to access all the installed apps.
3. In the AutoCAD/LT 2014 section (usually far to the right), click "Reset Settings to Default."
Message 48 of 58
pendean
in reply to: Emmsleys
This user has posted 6 times today in this forum, and you've answered three of them as if they were different.
Message 49 of 58
pendean
This user has posted six times today with the same problem, you've answered three of them separately. Let's focus on this one for now https://forums.autodesk.com/t5/autocad-lt-general-discussion/no-menus-in-autocad-lt-2014-running-on-...
Message 50 of 58
Well, that was it - all you had to do was overcome my inability to operate the down arrow in Windows 8, accepting that searching for AutoCAD was not the same as scrolling until I found the "Reset" button, and two nights of insomnia - I cannot thank you enough. I appreciate your patience with me as you taught me about this forum and in particular, the snipping tool - learn something every day, right? Anyway, all is as it was, and I am back to work. I thank you, my customers thank you and next time I will try to do better in how I approach a problem.
Message 51 of 58
pendean
You are most welcome.
Message 52 of 58
pendean
Message 53 of 58
pendean
Message 54 of 58
pendean
Message 55 of 58
pendean
Message 56 of 58
pendean
in reply to: sthompson1021
Message 57 of 58
pendean
in reply to: Binga
Message 58 of 58
Thank you for solving the same issue I recently experienced with my 2014 Autocad Lt.  I was able to reset the settings to default and the command ribbon was visible and useful once again!  Thank you!
Deb Stratton
Technology Administrators
