AutoCAD LT Forum
NC1 Files
4 REPLIES 4
6722 Views, 4 Replies
NC1 Files
Can anyone tell me if it is possible for me to create NC1 files from a DWG file?  I am drawing structural beams for a company that has a plasma operated cutting machine that operates with NC1 files.  They typically run the machine with NC1 files provided by a vendor that uses Tekla.
Thank you!!
4 REPLIES 4
pendean
You need to be using a version of AutoCAD called ADVANCED STEEL, or use some other program altogether that can read dxf or dwg file.
Thanks pendean. Can you suggest another program? I know I can create DXF files so could I possibly create a DXF and somehow convert that to a NC1?
Thank you
pendean
Thanks for the advice!
Technology Administrators
