AutoCAD LT Forum
MULTILINE TEXT window rotated 90 degrees
31 REPLIES 31
Message 1 of 32
36130 Views, 31 Replies
When creating (or editing) Multiline text in a file created in architectural desktop 3.3, the text window is rotated 90 degrees.  Is there a variable I can change that will keep the text window horizontal (or at least aligned with the text)?
31 REPLIES 31
Message 2 of 32
Charles_Shade
MTEXTFIXED set it to 2
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Tags (1)
Message 3 of 32
in reply to: Charles_Shade
Thanks, but it was set to 2, I tried 0 and 1 as well with no change.
Message 4 of 32
pendean
MTEXTFIXED is the variable to not rotate the text in the editor when editing, it will leave it at the angle it was drawn.
If you look it up in HELP, it has two restrictions and they have to do with MTEXTED: you seem to have applied the second option noted to it.
Message 5 of 32
in reply to: pendean
So there are actually two things going on with mtext; the first is when I double click on text, the editing window comes up rotated 90 degrees (or oriented vertically), and then when I modify the text and exit the text editor the text itself is then rotated 270 degrees.  I then single click the text, and change the rotation angle back to 0...  Kind of a pain.
I changed the MTEXTED to the "oldeditor" and that fixed the editing window from rotating 90 degrees, but then when I exit the text editor it still rotates the text 270 degrees forcing me to single click back in the editor and change the angle from 270 to 0.
Message 6 of 32
pendean
Do you have a rotated UCS or PLAN setting in the file?
Can you repeat the issue in any other file, or a new file?
Message 7 of 32
I just figured it out...  It has to do with the font type I selected in the text STYLE.  I had the true type font "Arial Unicode MS" selected, when I changed it to just "Arial", it works fine...
Here is a wikepedia link to what Arial Unicode MS is:
Seems like a glitch in autocad that it would rotate the text like that???
Thanks for your responses!
Tags (1)
Message 8 of 32
Well spotted Rob_ change to Aerial! The idiosyncracies of AutoCAD.
Message 9 of 32
it works
Message 10 of 32
Will this font issue be fixed in an upcoming update? I have found the same issue with RomansS font.
Message 11 of 32
pendean
There is nothing to fix: avoid fonts with "Unicode MS" in the name, they are not supported and Autodesk hasn't seen a need to make them compatible in 20-years.
Message 12 of 32
Seychellian
I am getting this issue with Simplex and Simplex 8. It happens in some files but not in others. I can't put my finger on why it's doing it and how to correct it.
I am drawing at a non-world UCS in a view that has been rotated and when I use Simplex or Simplex8 the font is following the world UCS when I type only.
Other fonts don't do it so it's definitely an issue with the font.
Bizarre!
Message 13 of 32
hwalker
in reply to: Seychellian
Can't add anything to this conversation, but I just have to say that your avatar is brilliant.
Howard Walker
Left Handed and Proud
Message 14 of 32
pendean
Post your DWG file, let's all have a look.
Message 15 of 32
Seychellian
Find attached 2 files where I have a changed the default font type (01. PSA - NORMAL) from Simplex to Swiss721.
In Simplex when you type the text it types at an angle (following the World UCS) in Swiss721 it types in a straight line (although if the text is highlighted it seems to do so at the same angle not matching the angle of  the text).
Both texts display at the correct angle once the text text dialogue box is exited.
Im baffled as to why.
Message 16 of 32
pendean
In both of your files, your text never rotates when editing your text or adding new text or mtext here.
But if I type UCS, then WORLD, the UCS icon in your two files rotates 45 degrees. And when I set PLAN to WORLD, all of you text rotates to -45 degrees in both files. so I guess your PLAN variable was not set to CURRENT UCS?
Message 17 of 32
Seychellian
Thanks for the assistance Pendean,
It seems to me that I have my PLAN variable set to current.
See attached video illustrating me changing this variable and testing it.
Message 18 of 32
pendean
Thanks for the video: You're on the MAC version, in Windows that issue does not happen here inside both of your sample files..
MAC forum is over here for your future posts https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520
Message 19 of 32
Seychellian
Hi yes, I'm on AutoCAD for Mac but seeing as this was a rather isolated issue that was being discussed here I thought it I would seek feedback on this forum and that it would apply to Mac. The issue described in the OP is essentially the same one I am having.
Message 20 of 32
pendean
Perhaps like the OP, on the MAC, that one font choice you have is a no-go and worth avoiding?
Forma Design Contest
Technology Administrators
