My text frames keeps disapearing from my AutoCAD dwg files.
I'm using AutoCAD LT 2017.
For the mtext.
In the Text frame in the properties box is "Yes".
When I open the file backup it shows the Text frame saying "No"
This maybe a software glitched.
So which ones disappear? How do I make one disappear, what steps are you using?
You have these two for example, they show all the time, even when I first opened your file.
HI @twilliams8,
Would you be able to make a screencast video of your workflow?
Or provided detailed steps on how you get this issue so that I can follow along and try to recreate the issue. As of now, I am unable to.
Thanks!
The only time that it does it is when you rename the file in the "Sheet Set Manager" palette.
Version: AutoCAD LT 2017.1.2
OS: Windows 10 Pro Service pack Don't know
