What happened to variables with MText settings? I think about how many variables there are for dimensions and I have to wonder WHY are there none for MText? I would love to be able to set my default justification, whether my background mask is on by default etc etc.
Insights and knowledge appreciated.
Solved by pendean. Go to Solution.
There is no system variable to set the default justification. But the justification can be changed all at once using the JUSTIFYTEXT (express tool)which is can be seen in the Full version of AutoCAD and not LT. Your requirements can be met with lisp, but again LT does not support lisp as well.
There have never been variables available for those settings. AutoCAD LT is a general-purpose program using settings designed to accommodate most users, if those settings don't work for you then try another program, or learn to work with what you have, or create your own macro's that use the justification that you want and put that in the ribbon, unfortunately background remains a manual setting only.
@Anonymouswrote: "...That's what the "automated" part of
Computer Automated Drafting is supposed to do."
CAD stands for "Computer Aided Design". Until we get some good robot help, it's not exactly automated.
