AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Mouse behaviour in Parallels on Mac
9 REPLIES 9
Message 1 of 10
5679 Views, 9 Replies
I've got AutoCAD LT 2010 running in Windows 7 under Parallels 5 on my Macbook Pro core i7
I'm getting erratic behaviour of the crosshairs when trying to draft.
There are two independent problems, depending on which view mode i'm in:
1.
In 'Cristal' or 'Coherence' view the crosshairs move with a lag or delay as i move my mouse. I've seen other complaints about this on forums, but no working solution as far as i can see.
2.
In 'Window', 'Fullscreen' & 'Modality' views, the crosshair movement is initially smother and more responsive, but then i'm getting a weird erratic jog effect when i try to pan around the model (by holding down the middle mouse button and dragging.
Both of these problems are incredibly infuriating and make drafting in Parallels a misery. AutoCAD LT is supposed to be supported in Parallels now so I'd like to know if there's a way of getting around this horrible UI glitch.
Thank you for any help in advance,
Lewis
9 REPLIES 9
Message 2 of 10
http://usa.autodesk.com/adsk/servlet/usearch/results?la=en&nh=10&col=wacjprd&col=usuppprd&siteID=123112&catID=123155&id=2088334&qt=parallels
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=7031104&linkID=9240617
http://www.parallels.com/support/
http://www.parallels.com/support/free/
http://www.parallels.com/support/chat/
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 10
Hey I have the SAME EXACT PROBLEMS word for word. Were you able to find a solution??? Email me at cityoffall@gmail.com.
Message 4 of 10
same problems here.
have you found a solution yet?
Message 5 of 10
pendean
Message 6 of 10
I've had the same issue running Parallels 7 and just in AutoCAD.  I'm currently using 2010, but I primarily use Revit 2010 and have had no issues there.   Here's what I just found and it works.  I just set this morning, so I don't know of any limitations...yet.
command line: 3dconfig
dialog window opens: click on 'Manual Tune' button in center-right of window
another dialog box:  in upper left corner, uncheck 'Enable Hardware Acceleration'
Message 7 of 10
HI
I'm also having this immense irritating problem on parallel 7 and autocad LT.
Tried 3dconfit and enable hardware acceleration...same problem.
Some more ideas?
fe
Message 8 of 10
Is there any resolution on this yet? I am also having mouse/crosshair issues in AutoCAD 2010 and 2012. PLEASE HELP ASAP!!!!
Message 9 of 10
Charles_Shade
Mac Froum to try:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
Any of the solutions noted here tried?
Is there anything that you have tried?
Has anyone ever asked this qestion in an Apple Parallels Forum to see if there is any insight there?
Message 10 of 10
in reply to: Charles_Shade
There is a message on the Parallels site saying it should be cleared up in Parallels 8. But nothing else!
Technology Administrators
