Hey I have the SAME EXACT PROBLEMS word for word. Were you able to find a solution??? Email me at cityoffall@gmail.com.
I've had the same issue running Parallels 7 and just in AutoCAD. I'm currently using 2010, but I primarily use Revit 2010 and have had no issues there. Here's what I just found and it works. I just set this morning, so I don't know of any limitations...yet.
command line: 3dconfig
dialog window opens: click on 'Manual Tune' button in center-right of window
another dialog box: in upper left corner, uncheck 'Enable Hardware Acceleration'
HI
I'm also having this immense irritating problem on parallel 7 and autocad LT.
Tried 3dconfit and enable hardware acceleration...same problem.
Some more ideas?
fe
Is there any resolution on this yet? I am also having mouse/crosshair issues in AutoCAD 2010 and 2012. PLEASE HELP ASAP!!!!
Mac Froum to try:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
Any of the solutions noted here tried?
Is there anything that you have tried?
Has anyone ever asked this qestion in an Apple Parallels Forum to see if there is any insight there?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
There is a message on the Parallels site saying it should be cleared up in Parallels 8. But nothing else!
