MLine works under AutoCAD LT, but not MLEdit?
HE-MJJ
Message 1 of 9
HE-MJJ
Why does MLine work under AutoCAD LT but not the MLEdit command?
Will this be moade possible in the near future.
Replies (8)
Message 2 of 9
cadffm
>>"Why does MLine work under AutoCAD LT"
That's wrong, it doesn't exist in LT.
Sebastian
Message 3 of 9
paullimapa
Have you tried Dline command
Paul Li
IT Specialist
@The Office
Message 4 of 9
pendean
Community Legend
Community Legend
In LT2025 and older, you can manipulate, trim, extend, copy and erase MLINE objects in LT, much like you can do 3DSOLIDS and other content added from full AutoCAD and the verticals.
But you cannot create nor edit them. So no MLINE command. And that's why MLEDIT does not exist.
DLINE command exists in LT, but it's nothing like MLINE. Sorry. And there is no DLEDIT command either.
Message 5 of 9
HE-MJJ
It does works from my own command using autolisp.
https://www.screencast.com/t/y36wdVZ0t1tj
Message 6 of 9
pendean
Community Legend
Community Legend
We don't have your LISP, so we'll take your word for it. Maybe.
You may have found an undocumented backdoor to MLINE command. Looks like you did not find one for MLEDIT yet. You'll have to keep experimenting to find it, if they left that door open for you.
Message 7 of 9
HE-MJJ
So it seems.
Message 8 of 9
HE-MJJ
Maybe I can use it. Thanks.
Message 9 of 9
cadffm
We can see that you dont start command MLine
and we see it is your own command,
but you didn't showing it is a mline.
But it doesn't matter.
Mline and MLedit are not native commands in LT, end of the story.
Note: MLEDIT is often not very comfortable, so you will find a lot of other codes to edit mlines!
What I guess, you simply insert an exiszting mline and you edit the entity data.
In fact, also your Lisp doesn't create a mline, it EDIT a mline and ther is still no mline command available in LT
Sebastian
