no paste option
no paste option
mmooney627XJ
Observer Observer
no paste option
mmooney627XJ
Observer
Observer
I suddenly cannot paste from a source drawing into a new drawing.  I can select the source item(s) with or without a base point but when I go to the destination drawing, I have no option to paste the work.  I have previously done this regularly (in other drawings) WITHOUT ISSUE
h_s_walker
Can you post both drawings so we can have a go?
The only thing I can suggest is see if it will paste into a blank drawing. If it doesn't try doing a repair reinstall
Howard Walker
Left Handed and Proud
cadffm
" I have no option to paste"
So you didn't copied something. I guess the COPYCLIP/COPYBASE didn't work.
Go to your source file, select your item (for a test, create a CIRCLE and use this circle for tests)
press CTRL+C
Go to the target file, CTRL+V and pick to the center of your current view.
Press F2 and read (and share) the last lines of [F2] dialog.
Sebastian
cadffm
Can we trust that you already tried a reboot before making the request?
Sebastian
paullimapa
Maybe try restarting your computer and that might clear things up.
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@mmooney627XJ wrote:
I suddenly cannot paste from a source drawing into a new drawing....
2) Did you restart your PC yet? Do that now if not.
3) Is there an error message at the source or destination file at the commandline? your commandline should be on, visible, and for now until your issue is resolved 5-10 lines tall so you can observe any messages from the program.
