Mleader layer changes when adding leaders
john77L59
Observer Observer
Message 1 of 13
john77L59
Observer
Observer
I recently updated LT 2025 to the latest 2025.1 patch and now my Mleaders are acting up. I will have a mleader on a layer and when i go to add leader line to it, the layer changes to what ever current layer I have. For example, I create a mleader and put it on a WALL-ANNO layer. Then i change my current layer to WALL-DIMS. If I add a leader (doesnt matter if it done thru the ribbon button or right click on the leader) it changes the layer from WALL-ANNO to WALL-DIMS. It never was like that before. I could add a leader and it stayed on the layer I put it on.
Anyone know whats going on?
Replies (12)
Message 2 of 13
cadffm
nice catch. It looks like Adesk added a good thing (the new MLEADERLAYER feature!),
but someone made a mistake in the implementation and also used MLEADERLAYER for MLEADEREDIT.
My personal opinion: Clearly a mistake.
Sebastian
Message 3 of 13
ahaynesYH4T9
Observer
Observer
It is possible to set a default layer for MLEADERLAYER. Enter MLEADERLAYER, then replace "use current" with "WALL-ANNO". (Yes type in the quotes also) However this must be changed in every file you open. And if all your leaders aren't on layer "WALL-ANNO" then this provides little help.
Message 4 of 13
mhaarmannB8YYD
It looks like the same thing applies when using REVCLOUD now.
Message 5 of 13
paullimapa
I wonder if 2025.1,1 update would fix this?
Paul Li
IT Specialist
@The Office
Message 6 of 13
mhaarmannB8YYD
Additional forum has the same issue and no one has seen a fix with any of the updates: https://forums.autodesk.com/t5/civil-3d-forum/adding-leader-to-multileader-puts-multileader-onto-cur...
Message 7 of 13
pendean
Community Legend
Community Legend
Sadly, no.
Message 8 of 13
ahaynesYH4T9
Observer
Observer
It did FIX it for me.  I can now add another leader to an existing one and it won't change the layer of that callout to the current layer.  I can now add a new leader and it does not change it's layer, just like it used to work.
Message 9 of 13
mhaarmannB8YYD
Are you running 2025LT?
Message 10 of 13
ahaynesYH4T9
Observer
Observer
Yes
Message 11 of 13
mhaarmannB8YYD
Lucky!! Congrats. Glad they fixed it for LT. 🙂
Message 12 of 13
pendean
Community Legend
Community Legend
Are you sure? Were you running the beta of the 2025.1.1 update by chance (and may still be)? in WindowsOS?
And you are using the button or the command AIMLEADEREDITADD command to add to the mleader, and not the MLEADEREDIT's default ADD option, yes (the actual documented workaround)?
Message 13 of 13
john77L59
Observer
Observer
Update:
No, the latest patch did NOT fix the original problem. The button still changed the layer to the current. BUT I did change the buttons command to MLEADEREDIT (as PENDEAN talked about above) and that works...for now.
