Help with .PAT file
Help with .PAT file
abbieF969Y
Message 1 of 8
Help with .PAT file
abbieF969Y
I am experiencing errors in my .pat file and unsure how to fix it. I am using Pattycake to create this 2D hatch, but AutoCad LT does not recognize it because of an error. Can anyone figure out what is wrong with the script?
Thank you for your time!
Replies (7)
Message 2 of 8
paullimapa
share this custom Pattycake.pat
also use About command, do a screenshot and share that here so we know what version of Autocad LT you're running
Paul Li
IT Specialist
@The Office
Message 3 of 8
abbieF969Y
Here is the pattycake link: Diamond Pattern Test
I am having issues attaching the .pat file, so I have pasted the text below:
I am using Autocad LT 2025.
Thank you!
*PattycakeDraftingTemplate2dx
;Generated from imported DXF file with 14 lines.
;angle, x, y, shift, offset, dash, space
0, 0.332, 0.3633, 0, 0.5, 0.2446, -0.66165
329.9314172, 0.577, 0.363, 84.8217398, -0.0014234, 0.2414995, -318.0987273
30.0685828, 0.577, 0.121, 233.518487, -0.0014234, 0.2414995, -318.0987273
0, 0.332, 0.1211, 0, 0.5, 0.2446, -0.66165
29.7448813, 0.12, 0.24, 28.1907695, 0.0155043, 0.2418677, -28.9838166
330.2551187, 0.12, 0.24, 1.0349148, 0.0155043, 0.2418677, -28.9838166
329.9314172, 0.577, 0.121, 84.8217398, -0.0014234, 0.2414995, -318.0987273
30.0685828, 0.577, 0.363, 233.518487, -0.0014234, 0.2414995, -318.0987273
29.7448813, 0.12, 0, 28.1907695, 0.0155043, 0.2418677, -28.9838166
0, 0.7864, 0, 0, 0.5, 0.1222, -0.78405
0, 0.7864, 0.2422, 0, 0.5, 0.1222, -0.78405
0, 0, 0, 0, 0.5, 0.1223, -0.78395
0, 0, 0.2422, 0, 0.5, 0.1223, -0.78395
330.2551187, 0.12, 0.485, 1.0349148, 0.0155043, 0.2418677, -28.9838166
Message 4 of 8
paullimapa
immediately install the 2025.1 LT update
Paul Li
IT Specialist
@The Office
Message 5 of 8
abbieF969Y
Okay, will do!
Message 6 of 8
paullimapa
worked on my 2025.1 but full AutoCAD see attached dwg & pat
Paul Li
IT Specialist
@The Office
Message 7 of 8
abbieF969Y
WOW, thank you so much! Your file worked!
Message 8 of 8
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
