Missing palettes at startup
FeeopEngr
FeeopEngr
AC 2019 Lt, WIn 7 64
So my Architectural Palette is miss again. I just did a reinstall but no luck. The paths seem ok (see pics), so no idea how to get them back. I tried changing the startup variable to all 4 settings but that didn't work.
Any suggestions appreciated.
Feeop
pendean
Community Legend
Community Legend
So this is a custom personal Palette that got unloaded? or the default from-Autodesk ARCH palette that comes with this version of LT?
FeeopEngr
The default palette
Feeop
Bob_Zurunkle
Did you check to see if your program is set to save any changes you make to the GUI?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
FeeopEngr
Please elaborate
Feeop
Bob_Zurunkle
Does your program show a little gear anywhere in the bar at bottom right? There should be a dropdown next to it. Expand that and one of the choices is Workspace Settings. Click on that and a dialog box pops up. Make sure to choose Auotmatically save workspace changes, then click OK.
