Hi all,
Recently started a new position and have been using some features that I'm not super familiar with.
My issue is that when I have completed several layouts and go to publish them ["Select All Layouts" > "Publish Selected Layouts" > "Publish to PDF" > "Publish"] the PDF set always appears to be missing a random number of pages as well as a random selection. Generally it will be missing two pages typically from the beginning of the set. When I have the "Publish" window open it indicates that all the sheets were loaded with the green check and "No errors" stated. Any help would be greatly appreciated, as having to individually plot and publish missing pages and insert them into the PDF can be quite time consuming when I have a lot going on.
Thanks in advance for any help.
-Kelly M
Solved by sage9HN5X. Go to Solution.
Hi @sage9HN5X,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
A little more information will help narrow down the cause:
All the best,
1) Version: T.53.0.0 AutoCAD LT 2023
2) OS: Windows 10 Pro [Version: 21H2 Build: 19044.1706]
3) Background publishing is selected as the default right now, yes.
4) Publishing to PDF.
5) No, am not introducing any additional templates or files.
6) Yes, Save constantly and always before publishing.
Thanks for the quick response.
-Kelly M
Thanks for the warm welcome, Cheryl.
1. The "Publish to" is set to "PDF" and the "PDF Preset" is set on "AutoCAD PDF (General Documentation)"
2. I will try using another plotter and see if I run into the issue.
3. Correct, Whenever this error occurs CAD is giving me no errors, either in the initial plot window or in the post-plot notification pop-up.
Kelly M
Cheryl & Pendean,
Thanks for your assistance and time. I seem to have solved the issue by switching the value of "BGCOREPUBLISH" from "ON" to "OFF"
Thanks so much!
-Kelly M
