I've recently created a new drawing and when I create my page setup my ctb file is not available. I am not sure where those search paths are set up! It's in the right place on my computer. I'm guessing I accidentally used a different standard file when I started. Can you advise how to point this drawing to the right search path? Thanks.
Solved by pendean. Go to Solution.
You can set up the plot style search path from "OPTIONS".
Type in the command "OPTIONS" go to "FILES" tab and then expand the "printer support file path' and then select "Plot style table search path". Now click on "add" and then browse the folder which has the "plot style"
I think it is, but have no idea how it happened, and can find nothing in Help about switching it back. I have verified the search path, so that is not the issue.
